I assume there was supposed to be a photo for us to look at?
I think you need to have been a member of the forums for a week before you can attach photos.
I thought i already did, sorry.
Anyway, the connector is right below engine oil cap. Is a 3 pin connector.
I unplugged the connector and reconnect, suddenly the car wont start and engine light came up
The engine light should be on if the engine isn't running so that doesn't necessarily mean anything.
Can you ID the component your connector plugs into from the diagram below?
Sorry for late replies, the diagram did not matched, i mean the whole diagram is correct but the placement of sensor/socket did not matched. The sensor/socket is right below the oil engine cap. I cant attach any photo or provide link to photo due to new member restriction.
Anyway, i already called an electrician to check with the car tomorrow, i will update as soon the problem figured out.
