Hello everyone,
I am in desperate need of help and have no idea what to do, so I ended up asking on this forum. I would appreciate any help if possible and if anyone has any advice on what to do because I am at my wit's end and I really have no idea what to do.
I have a 07 Hyundai Tiburon V6 2.7L. I have never had any problems with the car and never encountered any issues. However, living in the province of Ontario, I must undergo mandatory emissions "Drive Clean" testing, in order to renew my license plate sticker.
I went for my test, approximately three weeks ago. I failed. I had no check engine light, nothing. I had failed due to my MIL being "On" and the DTC "P0501".
Three days ago, I went and got the P0501 code diagnosed, and fixed. They ended up replacing the front right wheel speed sensor as the resistance was too high. I used an OBD 2 scanner 5 hours after the original fix, and checked. The scanner said MIL was now "OFF" and there were 0 Error Codes. I was happy and just continued to drive for the next two days as the mechanic had told me I need to drive around highway and roads to ensure all the monitors ready up.
It is now Sunday. I have driven numerous kilometres with a mix of highway and road. I used the scanner to check. And now I am completely confused. I now have two new error codes: P0441 and P0650.
I am starting to get very stressed and confused. I only have 7 days to get my car passed and I don't understand how new codes have arisen, after they didn't show up on the initial Drive Clean Test results.
Moreover, to make it clearer to anyone with knowledge, when I insert my key in the ignition and all the car lights come up on the dash for a moment, my Check Engine Light never comes on. I have never seen it even flash for a second.
I really would appreciate some help. I lack absolutely all knowledge in every aspect of a vehicle's mechanical components. I thought that addressing P0501 would fix the issue. I thought it did. Now I see these two new error codes and don't know what to do. I will also indicate that all my monitors are ready except, O2 Sensor, EVAP and Catalyst. I just need to pass my emissions. My car runs absolutely fine and I have never had any issue or noticeable symptom when driving.
Do I go back to the shop and ask them to fix the new codes? Do I go for an emissions and when I don't pass, say that they didn't address the issue? I have no idea? How much would fixing these two codes cost?
I have attached pictures to see if any of this information would help but I have no idea what to do and what to fix and what it will cost and any help will be appreciated.
I have attached a picture of the first failed test, the current "ready test" on my scanner and then the codes. I also don't understand how one screen says I have one error code and another gives me two error code numbers.
Thank you for your time,
OBDHATER
OBDHATER
