Ok so i installed a torcon bov sound plate on today and noticed that when i am under load or wot its letting alot of air pass through and when i close the throttle no air or woosh sound. To my understanding there boost should not be bleeding off through the bypass valve/sound plate at wot and should open when i close the throttle. I have ordered a new bypass valve today. And my car is a 2013 sonata 2l turbo limited modle. Any help to help fix this issue would be great thinking maybe a vacume hose is conected in wrong spot on the actuator thing under the by pass valve or wired backwards i dont no.. thanks for any and all input just want to hear the woosh sound when i let off the gas and not constant air flow at wot
