Hello everyone. Replaced power steering line in this car. Got it back, battery light was on and no heat,radio or fab coming on. Altenator died the same day, it was replaced and then wouldnt stay running. Put it new battery and everything else is working fine but still have no heat output, no radio and the blower fan wont come on. Checked all fuses and and they are fine. I am desperate to fix this problem.
I'm not sure which model of Accent a 2011 would be? Is that an MC model or an RB?
Regardless, what I'd suggest you do is remove the BLOWER relay from the engine bay fusebox and measure the voltage on the 4 terminals of the relay socket (ignition on). 2 of the terminals should show 12V. If there aren't two 12V being supplied to the relay socket the blower wont work.
When you figure out why the blower isn't working you'll have probably figured out why the radio isn't working too.
Let us know what you find at the relay.
