When I got into my car today my dome light came on and when I turn the car on a lot of lights on that panel stayed on, my headlights will not turn on, my radio works but the AC does not, and I cannot move my seat. Any help would be greatly appreciated
Check fuses and (especially) ground connections. Grounds are prone to bad connections over time, especially in salt belt areas, due to corrosion.
PLEASE HELP US HELP YOU. Click on your screen name and fill in all the fields marked with a pencil icon. We need to know what you drive and where you're located. The info you supply will show up in the left margin of your posts.
Turns out it was the 140 amp fuse. Whomever replaced it in the past, cross threaded the screw and it was loose.
