More and more person wants to use their Next-Gen console as a media player in addition to playing games. But for those who use MKV support for this format was not included yet. and this article will show you how to convert high-definition movie files(HD) MKV to MP4 AVI to play on XBOX 360 and Playstation 3.
First let's get a general idea about what an MKV is.
Part 1. What's MKV
MKV means "matroska video" and it is a "extensible open standard Audio/Video container"(not format, also can call"Multimedia Container") that supports various audio, video and subtitle compression formats. This file format combines several videostreams, audiostreams, subtitles, chapters and information in only one file. common AVl, VOB, MPEG, RM format actually belong to this type. however, they are either obsolete structure, or open enough, this led to a new type of multi-media package MKV format was born.
Part 2. How to play MKV file
VLC player can be used to open and play .mkv files. VLC player is a free, open-source media player for Windows, Linux and Mac OS X, that can play files of almost every format. The advantage of VLC player is that you do not have to install any additional codec (that many other players require) - this is because most codecs are bundled with VLC player.
VLC Media Player
Download Link: http://uberdownloads.com/software/video-player/VLC.html
Part 3. How to convert MKV file to MP4 AVI to play on PS3&Xbox 360
1.Convert MKV to mp4 and streaming MKV files to PS3 & XBOX 360 for free
GOTSent is a 100% freeware to convert .MKV (Matroska) video files to the .MP4 (MPEG-4) format. and the MPEG-4 is a widely supported audio/video format which can be played on the PlayStation 3, Xbox 360 or other portable mp4 players
And this part this we will explain the basics of using the free GOTSent application for the conversion(for PS3 user, you also can use mk2vob (Xbox 360 doesn't support VOB files though), cuz mk2vob only changes the container, it works fast and with high video quality).
What We need:
1.GOTSENT
2.AC3Filter - install AC3Filter for audio output settings
3.HAAliMedia Splitter - Haali Media Splitter must be installed for proper MKV file support
Step 1. install and run GOTSent. It's very easy to use, which has two input fields, one for input MKV, one for output folder (for MP4 file), allows you to select audio if there is multiple, browse subtitles, specify language and more.
Step 2. Add MKV files
To load an MKV file into GOTSent simply click File and use the file browser that pops up to find the MKV file you want to convert. You also must set an Output folder, you can do this by clicking Set Output and locating the folder with the browser that pops up. Next check to see if there is multiple audio with the drop-down box under Audio detected and select the language you want.
Make sure to select Split > 4GB as there is a size limit of 4GB for MKV files on Xbox 360. Fit to DVD is your choice. Before we begin conversion, we have to make sure that the audio that comes out is not multi-channel (unsupported by Xbox 360). Click AC3Filter Options.
Step 3.Configure AC3Filter Options
Based on the settings you put into AC3Filter, the conversion process will either create two-channel or multi-channel audio. Under Output format, change it to 2/0 - stereo to ensure compatibility of the output MP4 file with Xbox 360. When you are done, click Apply and click OK.
Step 4. Start Conversion
Click the Convert button to begin the conversion process. Several DOS windows will pop-up during the process, do not close these as they are important. The amount of time the process will take depends entirely on the length of the MKV file and the speed of your computer.
Note: The MP4 Files can be Played Both on Xbox 360 and PS3
2.Convert MKV to MP4 AVI to play on PS3, Xbox 360 with Daniusoft Video Converter
If you are looking for a fast & effient way to convert MKV files, Daniusoft Video Converter is quite a good choice, this powerful video converter supports all popular video even HD video,here is the main technical parameter
Input formats:
Common Video, HD Video, Audio:
MP4, MPG, MPEG, 3GP, RM, RMVB, DAT, MOV, FLV, AVI, Xvid, VOB, MKV, M2TS, TP, TRP, TS, AVI, MP3, WAV, M4A, WMA, OGG, AAC, APE
Output formats:
MP4, MPG, MPEG, 3GP,3G2, MOV, FLV, AVI, Xvid, VOB, WMV, ASF, M4V, MKV, MP3, WAV, M4A, WMA, OGG, AAC, AC3, APE, MKA
Simple steps to convert MKV Video files to MP4 for PS3 & Xbox 360
1. Click "Add" button to add MKV files.
2. Choose "MP4" as th
I use iDealshare VideoGo to convert unsupported mkv, mp4, vob, flv, mts or other video formats to Xbox 360 more supported avi or wmv
Thanks. To play MKV on Xbox 360 or other game consoles, a video converter is required. Personally, I use Joyoshare Media Cutter for video conversion and video editing. It can convert MKV to Xbox 360, Xbox One, PSP, etc at very high speed.
