Try dial xxxxxxxAnyone having a problem with phone commands? When I say "call xxxxx" the response is "say number"
The contacts list won't work. Is the problem with the phone or with the system?
Try removing the phone not working and go thru the setup again.I have 2 phones on mine that are both on the list. 1 phone works with voice command about 75% of the time, the other won't work at all!
Have tried that more then once, no differentTry removing the phone not working and go thru the setup again.
incredible. i should read the manualYou can just do "Call <Name> at <Location>", ie "Call Joe at Work" and it should work (you may have to confirm once).
Also you can do "Callback" (dials last number which called you) or "Redial". This doesn't confirm, ie dials straight away.
