Notice a fair bit of white cloudy smoke coming from exhausts daily basis.
Its not continuous just now and again for a minute or two. then stops.
Also are these cars known to drink up petrol like pretty fast?
How many miles on this vehicle?
Does it consume oil between changes?
Does it smoke only after sitting for hours?
That would suggest worn valve guides/seals.
My guess white cloudy smoke is oil burning. Steam from coolant dissipates quickly and may have a sweet smell. You can tell the foul smell of oil burning. Valve stem seals is my first thought. If so it will blow smoke on cold startup and after idling for some time then driving off.
not changed oil for several months levels of oil and coolant normal
mileage <70K
What year?
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page.
Shows up to the left.
  • * Be sure you are in the correct forum for your vehicle.
    * Do a search for your problem. A lot of stuff has been asked and answered.
    * Do not double post for the same problem..
    * Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly.
