1 - 20 of 21 Posts
My 2012 Sonata Hybrid started an embarrassingly loud belt squeak at 100K, so I replaced both belts. The intermittent squeak started again in a few weeks, so I change both tensioners and the pulley. The squeak started again after a month or so. The belt squeaks every time it comes out of EV mode. What could be causing this issue? Any suggestions?
alternator bearing, Check all pully bearings...
Take a screwdriver or a mechanics stethoscope and hear for rubbing noise...google videos of how this is done and go from component to component till you find the culprit...
This is the sound of bearing under load and when heated......
sandan
Send me VIN
sandan
Hybrid does not have alternator.. Belt for water pump (no tensioner),, and belt for HSG
What was source for both belts ??
I got both belts from RockAuto.
I run VIN, didnt have what I thought for 1 of recent Hybrid recall,,, but, look at nut at front of HSG,, there may be a paint line across front of pulley / nut... see if it still in line
You do have open recall for floor anchor (buckle) inspect with sticker install
Aftermarket belts,, hmm... almost prefer to OE supplied (Hyundai or Kia),, as sometimes store bought belts tend to be slight bit long (loss of tension), or of different material for grip pulleys (friction co-efficient) as spec by Hyundai / Kia for intended use,, I know, kinda sounds really off the wall...
Discussion Starter · #9 ·
I have replaced both upper and lower tensioners as well as the pulley. There weren't any paint lines on the new parts that I installed, so what would I be looking for?
So it is your suggestion that I buy Hyundai OEM belts and replace again?
Not looking for lines on the newly installed part.. Look at the "HSG" (Hybrid Starter Generator),, it is that big aluminum thing with small pulley that wide belt loops around.. there is a big nut on front that hold pulley to it' shaft,, some have paint line on them,, if it does, see if paint line still a straight line
You have sounds with non Hyundai-Kia supplied belt, maybe try OE supplied belt, as noted, aftermarket belts is generic for length, where as OE belt is made to spec for length and material for it' intended application
I am having the same issue with my 2012 sonata hybrid. I see a paint like on what looks to be a allen key on the front of the HSG is that what i should use to try and tighten?
To fix the pano roof there are a few descriptions on how to. It comes down to a crossbar in the roof with 4 metal screws that loosen up. The correction is to put felt pads between the two metals and retighten the screws.
For clicking, refer to the turbo sonata section, on a thread called ''Clicking....
im having same issue with 2012 Sonata Hybrid. Wasted $300 on belts...dealer wants $900 for tensioner..... need a fix , thx
2015 same thing I've tracked the squeak.
2 seconds after the ev light goes off it squeaks so what's the fix
Seems like the issue is definitely coming from the motor then. Hence narrow down to where on the motor. For mine, it was an idler pulley that made a lot of noise. Couldn't hear it much from inside the vehicle and windows up, but could with windows down or outside the car... I thought it was the starter/generator, took to the dealer (since I had warranty) and they said it was the idler pulley. I had them replace that under warranty and paid for a new belt to be put on since it is recommended to replace ~60K miles. Mine had about 45K miles at the time.
Hello everyone. I'm having sort of the same issue. I have a 2015 HSH YF. I changed belts (120,000 km or 75,000 miles). With the new belt, the chirping noise started. The mechanic (authorized Hyundai dealer in Guayaquil, Ecuador) says this is probably the belt, so we're changing it. He also said that it may probably be the tensioners (plural). He said that these tensioners should be changed at 120,000 km / 75,000 miles (such a coincidence). I'm skeptical. Is it true that tensioners have to be replaced at this mileage?
I needed to have my tensioner (not the belt) replaced at around 50K miles. Pretty crazy to me to have it go out so soon. It was making all sorts of noise, replaced under warranty. I went ahead and had the belt replaced as well at the same time (kept the old one for a spare) at my expense since belts are "wear" items with no warranty...
How much did they charge you for the belt?
1 - 20 of 21 Posts
