Hello.. Hope anybody can help with this querie.
My Passenger side window on the H1 has an intermittent fault - It will open but sometimes dosn't close.
I have renewed the motor and assembly and Renewed the switch on the passenger door.
I fitted the new switch which successfully closed the window - I then tried the old switch which worked!
The window opened and closed successfully for a few hours but has now stopped again.
I can only conclude from my limited experience that the switch and motor assembly are ok and that there is another fault possible a grounding..
ANY help would be appreciated from members..
Which switch is intermittent? If it's the one right on the passenger door then it could be a ground thing. If it is the remote switch on the driver's door then I would look for a broken wire where the harness passes from the body into the passenger door. Had this on my wife's car. The door locks worked when the door was closed but failed when the door was open. Two wires in the harness had broken over time from years of the door being opened and closed. For you one could be a ground wire. hhhhmmmm….
Need more info,,,
00000732
* Do a search for your problem. A lot of stuff has been asked and answered.
Thanks,
Welcome aboard.
