1 - 10 of 10 Posts
2011 SE, no other options.
Ended up getting smacked on the passenger side view mirror and there's a nice little hole in it. I'm looking for a good place to buy online (would that be the left or right mirror?) and instructions on hot to replace. I'm thinking a dealer would charge 2-400 bucks, auto body shop sub 200, but if i can do it for less than that, it would be great.
thanks
That would be the right hand side but if you want state the passenger side mirror. Sometimes ebay has them.
You can purchase a new mirror on line or at the dealer. I would suggest getting one already painted to match your auto. Its easy to change out once you have the replacement mirror. Remove the upper front plastic sail piece interior to the mirror location. The sail piece removes by popping it off from the edge. Remove the electrical connector by pressing the release tab and pulling apart. Remove the 3 nuts that secure the mirror in place. Install of the new mirror is the reverse of the removal.
You need the right side mirror as above.
I think all sonata mirrors are heated. They go on with the rear window defroster.
Ok. i didn't see that it had the heated mirror label, but it could be a "standard" feature now. I'll have to check it out once i get done with work.
looks like my problem will be finding a place to paint the thing.
yeah, i don't have the signal lights, nor is it heated(at least i don't think its heated). better than the $450 the dealer wants to charge.
I'm guessing you could get BOTH sides done with the signal light mirrors for less than the dealer wants for ONE w/o the lights.
Discussion Starter · #9 ·
does the standard wiring include turn signal wiring? i took off the door cover and saw it had 5 wires coming from the mirror (i didn't count coming from the car) i heard that 5 wires = power mirror + heat.
if i can get signals w/o having to pay the dealer, that would be cool.
1 - 10 of 10 Posts
