So I hit a deer with the passenger assembly and passenger side fender - fur was stuck in it, everything. Since I hit the deer, about a year and a half ago, it has been foggy inside the headlight whether it is day time or night. I took the assembly out of the car out once to replace a bulb and it was filled with water.
Is there any way to fix this problem? I was thinking of possibly sealing it, but with what? Or to drill holes in it to let the water leak out? Or just replace the whole assembly, it is about 60-130 without shipping. :liebe011:
i had the same issue with my aftermarket lamp - every time it rained my light was foggy To fix it i got the lamp out took the bulbs out and used hair dryer to dry all the moisture inside the lamp. than - as long as you don't have any cracks on the lamp surface you can seal it. i used an epoxy from home depot - 7 dollar fix just have to seal it all around
