hi are they any links to show how to take off and strip down both passenger doors ,due to someone running into side of me
ta
Sorry, I don't have any links. But you'll probably find a few videos showing how to remove a door if you go do a search on youtube. The videos don't necessarily need to feature your particular model of car. The procedure is pretty much the same regardless of what make/model your working on.
If you need to strip the window regulator, etc off the door I suggest doing that before removing the door from the vehicle. It will be easier to work on the door while it's still secured to the car. It will also make the door a bit lighter when it comes time to lift it off.
