Hi,
Unfortunatly, I’ve had a bit of a tip in my i40 tourer. It’s the base model, so no parking sensors or camera are fitted.
I’ve to replace my rear bumper as a result, but before I go and source one, if I were to buy a 2nd hand bumper with sensors fitted, are they just plug and play?
Or what’s required to make them work?
Unfortunately not. There is a bit more to the factory parking aid than just the sensors.
If you want a parking aid it would be a lot easier and cheaper just to buy an aftermarket parking sensor kit and install that rather than try to retrofit the factory system.
Really? I would have though that there would be some factory wiring harness I could just plug into, and just buy the compantsbthat were needed?
Was trying to avoid having to get an after market kit, as I don’t like removing a lot of trim to keep the wiring hidden.
You might be right. I don't know, tbh.
Regardless, I still think fitting an aftermarket system would be easier and cheaper.
