I don't use the parking brake on my 2012 very often. I engaged it in my garage recently when doing some work on the car. When I was done I released the foot lever, but when I went to back the car out, it was evident that the brake was still engaged.
I was able to get it to release by driving forward and reverse about 4-5 times, and I haven't engaged it since. But it will no doubt get worse, so I want to repair it.
Does anyone have any experience with this issue?
Each situation is different, but the most common issue I've seen in the rust belt is rusted "levers". Basically the parking brake cable wheel end attached to a lever that pivots and applies the shoes. When it sticks, the shoes drag. If caught early enough, you can work them back and forth while applying a penetrating lubricant and restore there motion. Then apply a proper lube to help keep them moving. You'll need to remove the rear rotors to access these. May need to use a punch and hammer to restore them to their initial position to allow for rotor removal.
Replacement isn't the most enjoyable process.
Thanks for the reply. I had the rear rotors replaced a couple years ago by a shop, one of the few things on this car I didn't do myself. They are a real pain to do at home. I'll probably take it in and ask them to check/lubricate the E brake, if that's the issue.
