I just test drove two Pallisade Essentials AWD, and both exhibited a vibration at 118 km/h or 73 mph.
I then took a follow up test drive with the head mechanic at the dealership who confirmed the vibrations.
They are now replacing and balancing the tires, and doing an alignment, then will re-test.
The dealer has also contacted Hyundai Canada.
They said they will update me once they know more.
I have found the same issue reported on the KIA Telluride forum by about 10 different Telluride owners. They are also working with their dealers, but do not have a cause or fix yet.
Has anyone else experienced this with their Palisade?
Discussion Starter #2
I heard back from my dealer today. They said that it is a bad front axle. They said that they had a similar problem with a bad batch on the Santa Fe about 6 years ago. New axle should be in in a couple of days and ready for a test drive.
According to the dealer, yes the replacement front axles fixed the vibration issue.
I ended up buying a different Palisade while they were testing the axle replacement, however I contacted the dealer today and asked whether the axle replacement was the fix for the ones I test drove with the problem. They said yes.
