Hello everybody,
I scraped the paint on the front bumper few days ago and I want to repair myself.
The scratch is very deep; it went through the clear coat, paint, and maybe primer?
But yea. I need some advice on how to repair this baby. I did some research and found out
that I need a body filler to fill the scratches, because it is pretty deep. Then I need to use primer
and paint and clear coat. Also I'm not using a spray paint because Hyundai only sells the touch up paint(brush type?)
So this will be a hard one. I already bought a Evercoat's Rage Xtreme. Can you guys give me some recommendations
on the good primer and clear coat? Also what is Sonata's paint type? lacquer or enamel? because I heard that you need
to use the lacquer primer if your car's paint is lacquer for example. Any help will be appreciated. Thank you.
