21 Sonata N Line
I'd like to be able to compare my readings with others if possible. I'm suspecting rear end repair and refinishing has occurred on my new N line. I'll have use of the guage over the weekend. If you could share your readings for the following areas that would great. Various points in trunk lid, adjoining top area of quarter panels that flow with the trunk lid. Thanks.
2016 Genesis 3.8; 2021 Sonata Limited
Sorry, don’t have access to a gauge, but if you’re confident that the front end of the car hasn’t been damaged, couldn’t you simply compare readings there to those on the trunk and rear quarter panels?
21 Sonata N Line
Discussion Starter · #3 · (Edited)
I did some mutli point readings. Averaging around 115 -120 microns average. Lowest area was the front door some areas were 100 microns.
Guys, check the front lower corners of your front doors and hood. Both doors passenger and drivers side felt rough when touching the corner. Upon magnificent it shows paint chip from new. Also the corner of the hood has clear coat drip.
