P2565 - Turbocharger boost control position sensor a circuit high
P2762 - Torque converter clutch pressure control solenoid control circuit range
These 2 codes are active on my engine. Wondering what the culprit would be. Read a lot about the waste gate actuator for the 2762 code, and wondering if I need to change the TBCPS to remove the 1st code. On startup, I do hear the turbo whistling pretty high but then it calms down after a couple of seconds.
Any ideas/help for DIY repair would be great.
Thanks
