Hi I am new to the forum and I hope you can help with this issue.
2 weeks ago I got a check engine light and code P2251 bank 1 sensor 1 O2 sensor. This is the upper sensor I believe.
I replaced the sensor and still get the code. I am thinking I got a bad O2 sensor right out of the box. Has this happened to anyone else?
Any help with this is greatly appreciated.
It is possible that you may have gotten the wrong sensor or bad sensor
It isn't unheard of .. does happen.
I would be more willing to check the wiring from the O2 sensor
Check the power to the heater on the O2 sensor
If you have a scanner that can give you data from the O2 sensor
Then you can see if there is a problem that way
I don't think that will be a valid trouble code for your J2 Elantra. There probably isn't anything wrong with your O2 sensor. That's why you still have the same code after replacing it.
Please take the time to fill in your forum profile with the details of your car, it's engine and what region of the planet you live in. That will help us to offer the most accurate advice relating to your vehicle.
My car runs fiNE then it wants to die at a idea sometimes but it usually has problems starting it just cranks and then it's flooded for some reason could that be my 02 senser
I have to to take the breather and hose out of then stick a cup in the hose to manually choke the carborater 2-3 times sometimes more where it's flooding on its own
Your starting issue can't be the O2 sensor since the O2 sensor signals are ignored during engine start. Plus, an engine with a carb won't have any O2 sensors anyway.
The 02 sensor I originally bought was either bad or not the correct one.
I wound up buying another sensor and replacing the one I previously installed. All good. Nor more codes.
Serves me right for buying a cheap 02 sensor on Amazon.
Ah, I see you've completed your forum profile now to reveal your working with a 2009 Elantra.
You posted to the wrong forum hence my confusion about the trouble code. That wouldn't be a valid code for the '96~2000 cars that this forum relates to.
Anyway, I'm happy to hear the new sensor cured the problem.
Scottie.
Related Threads
Hyundai Forums
1.8M posts
410.8K members
Since 2004
Hyundai Forum is a community for all Hyundai Owners to talk and learn all about their favorite subject: Hyundai cars from the Sonata to the Elantra and even the new Kona!
