EDIT your profile ---
Haymondroz
Junior Member
Location (where you at )
2001 Santa Fe 2.7L 2wd / AWD
Quoted: 0 Post(s)
(Thread Starter)
0711 is a trans fluid temp sensor circuit fault
2300 is not contained in USA Hyundai Motor Service site DTC menu for any of the control module used in USA (hence to location in your profile )
0430 is a Bank 2 Catalyst efficiency fault
Ok do you know where the transmission fluid sensor located on 01 Santa Fe 2.7 4wd
Remove the side pan, should be on the valve body
Dealer part counter fella look it up using VIN to properly ID vehicle build.. If they aint got it, PDC for Chicago area is in Aurora right along 88 at Orchard / Sullivan Rd area.... Use part number at Kia also, though their parts come out of same PDC also
