Hi,
I have a 2012 Hyundai Accent 75,000 miles. Noticed what seemed like reduced engine performance lately (slower acceleration, weird shifting and mpg) and check engine light came on. Scanned the code as P0456 very small evaporator emissions leak.
I checked for any obvious cracking in any hoses, and took out the purge valve to check it (it seemed perfectly fine).
I screwed on the gas cap as tight as it could possibly go also.
Can a very small evap leak even cause engine problems like this? I know larger ones would maybe throw off the fuel air mixture making it run lean and rough etc but seems like a dramatic change for a very small leak.
Does anyone have any recommendations for anything else I can check myself? Or am I stuck taking it to mechanic with a smoke tester?
Also, not sure if this makes a difference but I did hit a pretty huge pothole 2 days before the light came on, figured it might have knocked something loose but can't find anything.
Thanks in advance!!
Thanks in advance!!
