Unless you have emission test for licence plates,, drive it till wheels fall off,, otherwise you into (2) exhaust manifold
Which O2 sensors did you change? Post CAT or pre CAT. They may have been reading perfectly fine which I think is the case. Those codes are Cat efficiency codes not sensor codes. Do you have a scanner that reads fuel trims? If they are good(under 12%) your pre cats are probably worn out. If your fuel trims are out of wack something with the tune is probably causing it.
