Hello all,
I've been having an issue with my wife's car lately. Recently, the check engine light came on and the code it was giving was P0338. Soon after the car stopped running and so we towed our car to a local mechanic. He replaced our timing belt since a few teeth were worn, tensioners, water pump, the crank position sensor and 2 ignition coils. Two days later, the same fault code triggered the engine light after the car stalled out several times. (At random times, the engine will stutter then stall) Should we re-replace the crank position sensor or is the ECU the problem??
Thanks for the input.
