Hi Steve and :00000732: to the forums.
Hopefully someone will be along to help with the revving problem :thumbsup:
all i know about this is that there is an automatic choke,it normally goes 2 normal when engine warms up.best of luck with new car a great runaround.Hi folks, when starting my Atoz it revs its little gonads off then drops down to normal. Is this usual or is there a fix?
Just bought the car from a fella up the road that was gonna trade it in. 40k on the clock garage offered him 100 quid I offered 125! Apart from the revving issue all seem ok. :banana:
Possible coolant temperature sensor fault or the map sensor and/or associated wiring which is at the top of the manifold and goes to the bulkhead behind it.Hi folks, when starting my Atoz it revs its little gonads off then drops down to normal. Is this usual or is there a fix?
