Hi everyone. Just replaced our CX5 with a 2014 Santa FE 2.0 turbo. Love the extra space and room. I have a question regarding the ambiant air temperature sensor in front of the rad. Can I just replace the sensor or do I need to replace the entire bracket? It's easy to reach if I'm just replacing the sensor. Any advice from the gurus here? Thanks
Great thanks. The reason I ask is a new sensor comes with a bracket with the sensor attached. You're saying I don't have to remove the existing bracket. I can just pop off the old sensor.
More than likely it is in front of everything and behind the bumper cover. It would not be behind the radiator of condenser as they would be throwing off heat. my Gen Coupe has two of them in front on the support. I moved them and just used a wire tie to attach. They are above the horns.
Discussion Starter #7
100% agree with what I meant was it looks like the bracket attaches underneath and behind the rad.
445449
