How would a 17" Motegi SP10 fit on our 3G Accent? I like the wheel because it is fairly light and it seems to have the right dimension: 17x7 size, 4x100 bolt pattern and 40mm offset. What concerns me is the hub bore. According to eBay auction 200532257634, the hub bore is 72.6. Is this a bit too big?
I'm not sure if this will work but here is a link to the wheels on Tire Rack.
Thanks!
-- Boris
They look nice.  Not a fan of the 8 hole thing myself, but other than that, I like them.
What you'll have to do about the center bore size is get a set of hub centric rings. Our hub size is 54.1, so you'll have to get a set that is: Outside Diamater: 72.6, Insid Diamater: 54.1.  Otherwise you will either have a bumpy ride, or your lugs will break off... Or both.
Thanks for the link. Yep, I'm good with the rings and totally get it. I guess I was a bit unsure of the amount of compensation needed done by the rings. Is the leap from 50-ish to 70-ish too big? Should I be looking at a different set of rims? Etc...
-- Boris
