I noticed that at 15000 km the oil is 1.5 liter less.
One liter in 10,000 km is a bit inconvenient, but within normal range.
You need to start checking oil at least every 2000 km and top off as needed.
Most Owners Manuals recommend to check the oil every time you get gas.
Modern engines use low tension piston rings to reduce friction and fuel consumption.
The consequence is some of those engines use a little oil.
It's not just Hyundai.
