1 - 9 of 9 Posts
I change my own oil and I need an oil socket wrench. I use Hyundai oil filters, so I need a socket wrench that will fit that filter. If anyone knows where I can get one it would be greatly appreciated.
the oil filter is above a plastic cover at the front right side behind the fender, the cover is held in place by two 10mm bolts, you can then remove the oil filter, if its more than hand tight you can use any standard type of filter wrench to loosen it
I know where it's at, I was just looking for an end cap oil socket type so I can use a ratchet wrench on it.
I'm sure that there are many more options, I just did a google search for "oil filter wrench", and that was one of the results. Google is our friend.
The OE Hyundai blue spin on oil filter has the same waffle as 1 of the old Toyota Filters before Toyoa went to mini filters as their new revised part...
I use my old Toyota cup for the Hyundai spin on filter.
1 - 9 of 9 Posts
