Hi im recently trying to add an mechanical oil pressure gauge in my 1.5 01 Accent and I can't seem to find where the oil pressure switch is at so I can take it out. Does anyone know?
Thanks.
I have looked on hmaservice.com but all it shows or tells you is a diagram where all the cluster sensors are. So it just shows it under the hood, no specific place. I looked above the oil filter and the only sensor I can find is the temperature sensor.
I found it!! I was located on the front of the block right underneath the right side of the exhaust manifold. Thanks though.
