  • hi, i’ve got oil leak from flexi pipe wich comes from vacuum pump,can you give me part number and some info about it? Is it possible for temporary fix as hyundai closed and not possible to get new pipe and what is the corr name for that part
    445777
Should find any D4EA motor should have one fiited KIA/HYUNDAI . I guess you've checked the joint is tight and not leaking at the washers
3739227400
PIPE-OIL SUPPLY TO VACUUM PUMP
