Hi All,
I'm a new owner of a 2005 Terracan 2.9 crdt Manual. I have found a oil leak which only seems to run when the engine is hot (no dripping over night when parked up) however there is plenty of oil on the block and other parts below the sump. It looks like it is coming from high up on the drivers side of the engine block behind or close to the alternator. Injectors, cam covers and the timing belt cover/box are dry although there is a little oil residue in the intercooler pipes (may be normal?)
Any ideas what it may be coming from? gaskets? pumps? etc
Thanks very much Rob
May be simple like a tappet cover gasket. I suggest you wash the engine and inspect it regularly for the leak.
