if you remove the oil filter you will find that the oil cooler is held in place by a large nut, it may well be that this nut is not fully tight and that may cure your problem. if not you can undo the nut and remove the oil cooler and you will find there is a large rubber 'O' ring that seals it which can easily be replaced
