Hello,
Recently bought a 2012 Hyundai Sonata 2.0T with 100k miles. This happen around 12/9/17. After a month it started to idle rough and start really hard. I research the issue and replace the ckps, battery and was ready to replace ignition or pump.
I saw that cylinder 1 & 2 had oil. I bought a line and vacuum it out.
That is when I decided to clean the throttle body. I discover there was oil on the line coming from the intercooler. Like about 1 quart.. The car did not start before. I cleaned the throttle body, clear the piping and everything back to normal.
Have rough idle but was wondering if there is anything I should be aware of. I Will take it to the dealer for the oil line recall. I'm thinking that is the reason for all this.
Thanks again.
Thanks again.
