I have a 2015 Hyundai sonata (2.4 L) 113,000 miles.
This thing is using a lot of oil. 1.25 qts. in 1000 miles. Had the car at the dealer for oil consumption test. They say it's using more than it should according to Hyundai. According to the dealer. Hyundai specs. 1 qt in 1000 miles. I think this is way too much, but they say this is in Hyundai specs.
They notified Hyundai of the problem. Hyundai says I must spend $1000.00 to have the intake valves cleaned before they will consider replacing the engine. Dealer says Hyundai claims cleaning the intake valves will cure the problem 90% of the time.
So, I spend $1000.00 and it it stops using .25 qts in 1000 miles, then Hyundai isn't going to do anything, because they claim 1 qt every 1000 miles is "normal "!
If it still burns 1.25 qts after the intake valves are cleaned, I guess there's zero guarantee Hyundai will even replace the engine. Or if they do, what will it cost me 10%,20%,etc,.
I just replaced the intake on this car last week due to intake runner code.
I noticed all the intake valves, and cleaned them myself before reinstalling the intake.
The valves weren't what I would call real bad dirty/gummed up, but I cleaned them.
1000 miles later, still burns 1.25 qts of oil.
Guess I'm stuck with this thing, but I'll never purchase another Hyundai.
And I really doubt Hyundai cares if I ever buy another Hyundai, but someone else can be the sucker.
I won't be screwed by the same company for a second time. That's for sure !
Rant over. what are your thoughts here ?
Thanks ..
Thanks ..
