Hi, I have an 02 tiberon with 40k on the clock. the engine burns oil. when i remove the plugs the no1 cylinder is the only plug that has an oil coating on it. i have changed the pcv valve (which did nothing). the local repair shop comression tested the cylinder and said that they were all in line, however they are telling me i have a leaky valve seal and it must be replaced. which invloves removing the head and getting charged much money.... has anyone had this problem before and does this sound accurate??? and help is apprecited...
