As am I, as well as how you went about wiring the speakers in the doors.I'm very interested in your results.
Yes this would make the job easier and cleaner. I have thought about it, although I am not afraid to cut the stock wires. I think this will be a permanent upgrade... then again I might want to yank it out when I sell the car... I could always just resolder all of the connections later, but that would be a pain in the ass.Ah, now I understand a little bit more. Cutting the harness would be a deal breaker for me. I just don't even want to go down that route in case it ever has to be returned to stock, especially while the warranty is still active. But, after reading this yesterday I did some research and found that they make "reverse" harnesses for a lot of cars, not sure if ours is one of them or not. This basically is a harness that plugs into the radio and has all the wires coming out of it to be spliced to a damaged factory harness. I think this would be something worth looking into for this application. If found, you could cut and splice that to a regular radio harness and then just split off the speaker wires as needed. This would also allow all cutting and splicing to be done outside of the car, which is also a good thing in my opinion. This would definitely make for an easy way to wire up an amp to the door speakers if the parts for our car are available!
You should dial back the gains on that clarion amplifier if you are not able to turn the volume on the HU up to 26 or 27. An amplifier is not set up correctly if you can only tun your HU up to 10.Just an update for anyone interested. I picked up the XC1410 and installed it this weekend behind the stock head unit. There was just enough room to make it fitt. I ran 12 gauge power wire though firewall using the grommet that the hood release cable goes through. I tapped into the speaker wires from the stereo back harness. It was a little tricky to install but well worth it.
The results: The volume is much louder. At 10 it is loud like 30 before. Even at 5 it is loud enough for normal driving. At 20 it is very loud and very clear. No clipping at all and ear plugs are encouraged (joke). This is very nice because the volume can be adjusted from the steering wheel in only a few clicks. As for the sound quality, it is much better. The bass is stronger, the highs are clearer, and the mids are improved. If I turn the bass up it sounds like there are subs. Keep in mind that I am still using the stock paper cone speakers. I plan to upgrade them in the future and anticipate that will be a nice compliment to what I just did.
All in all this is an upgrade that was well worth it.
Well that is the one downside of this amp. There is no gain control. Kind of stupid. I can turn the gain up to 25 without distortion no problem, but keep in mind that it is VERY loud, much louder then you are getting from 40 off the stock head unit.You should dial back the gains on that clarion amplifier if you are not able to turn the volume on the HU up to 26 or 27. An amplifier is not set up correctly if you can only tun your HU up to 10.
Do you have any issues when listening to the radio, or when streaming music via auxiliary or bluetooth?
If the problems only come from playing cd's then it is definitely a head unit issue. CD laser could be out of whack. If it comes from other forms of media it still could be from the head unit but I would look at the speakers or amp. Does it do it at low volumes or only high volumes?
To trouble shoot I would do the following.
- Try connecting stock speakers if you still have them (you don't have to install just connect). If it stops then it is the speakers.
- Try changing the amp (just as a test if you have spare or know someone who does) or running directly from head unit. If it stops then it was the amp.
If you often listen at very high volumes it is possible that the tweeters are blown. Also audio books do not have the complexity of sound as music does with highs and lows, so you would be less likely to hear any problems that you may have.
These are my first thoughts.
To me it sounds like you're using crappy CDR's. Try some verbatim and burn them at 4X or 2X. Older analog source music when digitized has audio quality issues anyway, but cutouts, skips, anomalous noises and such can be poor quality media. Try something better before you burn a lot of money on a new HU. I have a few select CD's that I play, because MP3 isn't good enough, and they are on Verbatim media. Sound is just like the original CD, which is put away for safe keeping.Hi all I have a couple of questions for discussion. I have a 2013 gt I upgraded to a Rockford fosgate amp with M B quart speakers . at first the sound was great but recently I have been getting sounds from the tweeters like it is blown also very odd cut outs . the head unit is the non nav factory unit. related facts 1) most of my cd's I have recorded from my computer mostly fair quality cd's. 2) some are getting older 2-3 years. 3) if I listen to factory recorded cd's and my personal favorite is audio books I have considerably less sound problems.
so do you think most of my problem is from quality of head unit and older cd's. would spending money for a new head unit all but eliminate my sound problems.
thanks for your comments and advice. have a good day. and remember you cant fix stupid even with duct tape.
Get yourself a couple of these...plenty of room!well I only use Memorex . verbatim , and tdk. the problem cones when they age . no cure for that. the majority of my stuff is audio books. the more I ask and get ingo back it would seem the head unit may be most of the problem.
Amazon.com: Kingston Digital 32GB DataTraveler Micro USB 2.0 (DTMCK/32GB): Computers & Accessories
Playback is flawless as long as you have a good original.interesting maby I have a couple of these around i'll give it a try dot sure about play back but maby thanks for the thought.
Good recommendation. I have one plugged into my car and not only does it function flawlessly, it's so small you hardly notice it.Get yourself a couple of these...plenty of room!
