Hi I have an Irish Tucson. The trip computer has a little km sign next to it and the speedometer is only in km. Can I safely assume the Odometer is in KM too? Its just other tucson I've seen have a km or miles symbol next to the odometer and mine doesnt....
I would think that all the instruments would be either imperial or metric depending on the country they are made for.
I suppose if you drive at a set speed for a fixed time on a moterway should give you a good indication. Big difference between kms and miles.
If the speedo is marked in km only then the odometer will be km too.
But if you want to confirm drive at 60km/hr and you should be adding 1km to the odometer every minute.
