Clarify "not start"
Turn key to start :
instrument cluster warning lights illuminated
solid click
rapid cyclic clicking
crank with no fire
no click and no crank
Did you plug the connector back together at the corner of batter tray that was single wire in round type connector I think it is ?
hyundai won't start
sometimes crank with no fire other times cranks but won't idle and run just shuts off
Which engine ??
"DRIVES" info under your user name does not say Santa Fe 2.4 or 2.7 or 3.5
If 2.7,, I would tell you to inspect the crank position sensor pigtail where it meet sensor body for cracking of outer sleeve,, or missing section of sleeve allowing the 3 wires inside to be exposed with their respective insulation cracking off..
Know a fella out the name Chuck Tooke ?
