1 - 1 of 1 Posts
My '08 Azera Limited developed the problem of not blowing cold air from the A/C to the passenger side over the summer.
I had the passenger side actuator replaced behind the glove compartment and the problem was solved.
Yesterday we had the heat on and I noticed that only the driver's side was blowing out heat. The passenger side was blowing cool air no matter what temperature setting you chose for that side.
Can the actuator need replaced again on the passenger side or is it something else.
Since having the first actuator replaced by my mechanic in Missouri we have moved to PA. I have no trusted mechanic here and don't want to take it to the dealership without knowing pretty much for sure what is wrong.
Thanks so much,
Mark
1 - 1 of 1 Posts
