Hello everyone I am a new member here with a question about a 2009 Hyundai santa fe gls that I am fixing. I replaced both front strut assemblies and strut mounts on this vehicle, after the struts were replaced the car makes a knocking sound when going over bumps while driving at low and high speeds, the struts are very tight and I made sure that both new strut mounts are as tight as they can get without stripping the bolts, I then resorted to replacing both stabilizer links that attach to the struts and the knocking sounds is still there! The noise started happening immediately after I changed the struts and mounts! Everything is tight and I cant figure out what is causing the sound. Please help! Thank you
The usual suspects will be sway bar bushing. Both the front and rear too. Then the lower ball joint or control arm and outer tie rod. Basically the suspension system check.
