My 2015 Sante Fe Sport 6 cyl suddenly lost both tail lights and the plate light on the driver's side only. All the bulbs are good. I checked continuity between the tail light socket hot and ground and got .7 ohms, the same as the working side. All brake lights work fine as well as the turn signals. When I tried the turn signals the passenger side works correctly the two bulbs on the tail light go on and the bottom outer (brake light) bulb blinks. When left turn signal is used the bottom outer bulb blinks and the the outer top (tail light) bulb blinks also but dimmer than the turn signal. The same happens when the lock button is pushed. When the unlock button is pushed, the working side tail lights go on and the bottom outer bulb blinks twice. The left side top outer (tail light) and the bottom (brake light) both blink twice but the tailgate tail light only blinks once. I changed the smart junction box only to find the problem still there as well as the driver's side headlight led trim light and the DS side marker are now also not working. I have verified that all fuses are good. Can anyone she'd some light as to what may be the problem. Thanks
