2007 Honda CRV
Got fuel, got spark, compression and timing
Cranks but will not start
When spark plugs are removed, the spark plugs are wet.
Check spark and there is spark
Removed valve cover and see that timing and belt are good
The engine will start when injectors are unplugged and starter fluid is sprayed into intake
Am suspecting bad grounds on injectors??
Wet plugs may spark OK outside the cylinder but not under compression. Your ether is much easier to start the flame front than gas. Use a propane torch and burn the fouling off the plugs and try it or put in a new set.
This must be the Honda you're talking about. Did you get it fixed? If not can you fill me in on the vehicle details.
