Okay everyone, I have an issue with my 03 Hyundai Tiburon 2.7l. I changed the spark plugs and wires and plugged everything back in like it was and now the car will not start it just clicks and the battery light flickers when I try to start it every time. Tried to unplug all the sensors then unhook the negitve battery term. Then plugged them in and hook the battery back up but that did not work. I also changed out the crank shaft position sensor and made sure that was plugged in too. Please help i did all the work myself and I feel that I am missing something.
Are you saying you have a no crank, no start?
Or are you saying you have a crank no start?
The two are different and require looking into different components
Sounds like your battery has just gone flat. Do you know someone sensible that might be able to give you a jump start?
Or you could just recharge the battery and see if that helps.
