1 - 8 of 8 Posts
Hyundai sonata.
Broken ecm. Im change the ecm now no start the car. Meter bord not coming key light... Coming this code p169A..
What problem the car
Why did you change the ECM?
Your car has a transponder key immobilizer, so can't just fit a replacement ECM. Your ignition keys are not coded to the replacement module so the engine wont start.
You fixing this yourself after an accident?
Discussion Starter #7
  1. Your car has a transponder key immobilizer, so can't just fit a replacement ECM. Your ignition keys are not coded to the replacement module so the engine wont start.
    I change now ecm. And ignition key smtra immo change... Now no start dash bord not come key light.. Ecm locked show scanner
Maybe talk in your own language and we can use a translator.
1 - 8 of 8 Posts
