Hello. I own a 1998 Hyundai Excel. When I went to start it up in the morning there is no Power. So I thought the battery was flat so I fully charged the battery still no Power. there is no ignition light on the dash. would it be the Electronic ignition gone and how can I test it. I hope you can assist me with this problem. Many Thanks Terry.
MODERATOR
does the light come on when you open the door?
how about when you blink your high-beams?
any noises or dashboard lights when you turn the key?
check your fuse= all of them
you said you charged your battery. that doesn't mean the battery is not the culprit. it may be holding almost no charge. get it tested.
