Have a 2007 Santa Fe (2.7 engine). Vehicle has new battery (2 months old). Walked up to car with remote to unlock the doors and it would not work. Used key to unlock the door. Put key in ignition and everything is dead as if no battery in the vehicle. Pull out jumper cables and jump start the car. It fires right up and stays running when cables are disconnected. Drive through parking lot at work and car shuts off as I slow down and have no power. Jump start the car again and fires right up again. Drive around the parking lot slowly then hit the accelerator to speed up and car shuts off again with absolutely no power. Remove battery and take to store to see if it is good. Battery is charged at 100%. Car parts guy suggeats that it may be bad camshaft or crankshaft sensors. Go back to the car and put battery back in it. Jump start again since no power. Drive it out of employee parking lot where it turned off again when slowing down for stop sign. Had vehicle towed home.
I ordered the parts that the guy suggested that causes car to shut off while driving. But those would not cause the no power issue to just unlock the car doors and have to jump start the car. Could it be the battery cables? Terminals on the cables are brand new and clean.
