I am a new member and this is my first Hyundai. I own a 2005 sonata 2.4 4 cylinder. I replaced the crankshaft position sensor and still have nothing. Please help me figure this out!
I'm happy to try and help but it would probably be best if you started a new thread on the Sonata forum relating to the problem.
It might be a good idea to check that the crank sensor has a good power supply and ground. Connect your black voltmeter probe to the black wire terminal on the sensor's harness connector then touch the red probe to the two other terminals. With the ignition on you should get approx 12V on one terminal and approx 5V on the other.
2007 Honda CRV
Welcome to the forum
Please fill in the profile
We may need to know where your car lives and how many miles it has
The year of the vehicle
Also, a good description of the issue you're having
And some steps you have taken to diagnose the problem
