1 - 20 of 20 Posts
The QT stations in Atlanta have added No Ethanol gas. I tried a tank. I was surprised to see the octane rating was 87.
I have now used regular, mid-grade, and premium. No Ethanol was the lowest MPG. Followed by regular, premium, and mid-grade.
I did similar tests with three 4 cy Camrys over the years. No No Ethanol of course, but mid-grade always was around 10% better.
Interesting, I have been using 100% gas for a couple of years now, (87 octane) as both of my vehicles get 3-4 mpg increase. The price is a break even for me, higher cost offset by the increased mpg but a further price differential will kill the 100% gas for me.
I've always received about a 6-10% increase in fuel economy when using ethanol free fuel, but it is typically more than 10% more expensive than comparable E10 fuel. A lot of stations around here have ethanol free 89 for boats, but it typically runs 15-20% more expensive than E10 89.
In Atlanta the mid-grade costs 5 - 8 % more than regular.
I started using mid-grade when my 1989 Camry was pinging on a slight upgrade on the way to work.
So the cost vs mpg is roughly equal, but the performance is better.
Given a choice, I would prefer to use non-ethanol fuel. Your car will run "cooler" and you don't have to worry about the side effects of ethanol.
Ethanol free will technically give you at least a 3-5% boost in MPG as gasoline has a higher energy content by volume than ethanol.
Additionally, you will get zero mileage difference between using fuel of a different octane rating because octane rating has nothing to do with energy content, the energy content is the same for all three fuel grades.
The reason you're getting the results you are is test method error, MPG varies based on driving style, and you the operator and not blind to the test condition. Control for driving conditions, blind the operator, and gather enough samples sizes to compare means of the varying test conditions, then report back ;-)
Discussion Starter · #9 ·
My driving and conditions are almost unchanged over time. I've had this car for nine months and have driven 3400 miles. Almost all on residential streets to and from my golf course. With two of my Camrys most of my driving was the same 25-mile route to and from work.
Doesn't matter, you'll still be subject to variation in how you accelerate, temperature, how many red lights you hit, etc. I have the same commute and generally same-ish destinations on the weekend, and my mileage varies by 5-10% every week i fill up. That's without switching fuels. You can expect the same level of variation in your driving style as well. Since you are looking for such a small response in your data, you will need multiple sample sizes in order to truly run your experiment and draw a reliable conclusion.
The other reason I say that you have test method error is simply that the science itself doesn't back up your conclusion. The link I posted above is at least one reliable source stating that non-ethanol fuel will give you around a 3% mileage increase. Any reliable source on the internet will also state that an engine designed for 87 octane fuel will not benefit in any way from use of higher octane fuels. Octane measures the anti-knock (or rather, the ability of the fuel to withstand premature combustion during compression) ability of a fuel, not its energy content, the two are not related.
Discussion Starter · #11 ·
A 14-gallon fill-up lasts me a month, 20 trips I'm guessing. I've never counted. Any variation in driving style should wash out over that sample size.
Its been 2 years, and I've concluded my study. You were in fact correct.
The ONLY 3 vehicles I have ever driven that NO-Ethanol fuel clearly shows a benefit... My riding mower, our Polaris jetski and the Mercury outboard on our pontoon boat.
I only use non ethanol fuel in my Lawnmower like Shell V Power gas for Lawnmower & diesel V-power in VW Jetta so far its helped clean out the DPF Filter in my 2012 substantially with-out a doubt i would not bother using anything else other than shell V- Power in any Gas or Diesel. (y)
Can't find no-ethanol 87 octane around here. The one place I found was 91 octane and the station wanted 70 cents more per gallon that the ethanol 93 octane pump right next to it.
Michigan lacks any laws where the gas station must display a sign on the pump that our fuel-of-choice does not contain ethanol. A few years ago, the law was erased where gas stations had to display ethanol at that particular pump. Stations are no longer required to do so.
what does ethanol free do to engine warranty on 2018?
No warranty issues. It's just "uncut" fuel, so to speak. Think of E85 as blended with filler. Non Ethanol has no filler. E85 is a mix that's compatible with ALL vehicles. Most vehicles can't run on %100 Ethanol but all vehicles can run on %100 Ethanol Free and E85 mix.
I wish we had Ethanol free gas locally,the closest one to me is a no name station 40 miles away, I would buy it for my car and generator!
apparently it is pretty easy to pull the ethanol out of gas.
not that it isn't work, and it is a bit much to do it for 15 to 18 gallons.
but a few gallons for a lawn mower would be fine.
since ethanol is water soluable and gas and water don't mix, the people pour water into a container with gasoline in it. mix well and let it sit to seperate out.
pour off the water, which you will see has increased in volume and you have ethanol free gas left in the container.
lot of youtube videos on it.
That's just got "Accident waiting to happen" written all over it.
1 - 20 of 20 Posts
