I've lost all displays on the audio screen. I can hear the radio, take phone calls but I can't see the stations, change settings - I saw a post that the person had no sound & was told to use the reset hole near the CD player. Should I try that?
Welcome to the forum. By all means try that. You may also want to try disconnecting the negative battery cable for a little while, and see if that helps. Otherwise, say hello to your all star dealer.
Retired Staff
Rather than disconnect the battery terminal you can just pull the radio fuse
